Set material color1 according to color0
Home Forums Puzzles Set material color1 according to color0
  • #63175
    matin00x
    Hello to everyone,
    I have this material in Blender where i have 2 Principled BSDF shaders mixed with mix shader and there is a texture connected to fac of the mix shader.
    I would like to change the Principled BSDF Color.001 – color of the 2nd Principled shader
    according to the Principled BSDF Color. (this color is changed by user)
    Lets say if the RGB value is higher then 128, then it change.
    Or maybe it would be easier just to set colors for which the Principled BSDF Color.001 would be black .
    Could anyone help me with this please ?
    #63177
    You can’t compare a color in the RGB format with a number. An array of numbers cannot be less or more than one number. Your condition will always return false
    #63179
    matin00x
    Hi
    Thats what i thought can i compare the RGB values somehow ?
    #63180
    Compare the red, green or blue channels separately.
    The range for these values is 0-1.
    128 corresponds to 0.5
    #63181
    matin00x
    I dont understand how could i place the RGB values in the get color puzzle. Could you show me please ?
    maybe something like this ?
    https://www.soft8soft.com/docs/files/puzzles/puzzles-materials-get-color.jpg
    • This reply was modified 1 year, 8 months ago by matin00x.
    #63183
    #63186
    matin00x
    Thanks for your help kdv, but I did not have much luck with your setup,
    when i adjust it to this.
    the Principled BSDF.001 Color changes according to the value in the “if part”
    0.08 – is the threshold for some reason ?
    But it does not change regarding to Principled BSDF Color.
    #63188
    Use this puzzle. See inputs, outputs, condition in the console log.
    Have no idea what are talking about.
    #63190
    matin00x
    Yes you are right. That was actually the best advice !
    I got it working with the puzzle i posted above just swap the LSB material to the variable i am placing the “variable material”
    I am a bit lost in JS so in the Verge puzzles also, but slowly thanks to Verge i am getting better :-D
