set domElement of orbit controls
Home Forums Programming set domElement of orbit controls
  • #29278
    thomasup
    we are using html divs anchored to 3d objects, so that the divs float above (and move with) the rendered 3d model. similar to the scooter example application, but with html elements rather than 3d discs.
    but, unfortunately, this means they block mouse drag events (for rotation) when the drag is started inside a overlay div.
    in pure threejs, our approach would be to pass a domElement to the orbit controls in the constructor.
    is this also possible within the verge3d “app” structure? because, as far as we understand, the v3d “app” is initializing the orbit controls, so are there parameters we can pass / influence to what domElement the events are linked?
    #29710
    You can use the App.enableControls method. It receives an HTMLElement as a parameter and passes it into the OrbitControls constructor. You can do that after the app is loaded, for example in the standard runCode function:
    function runCode(app) {
        // add your code here, e.g. console.log('Hello, World!');
        app.enableControls(document.getElementById('v3d-container'));
    #29738
    thomasup
    that works perfectly for us!
    thanks :good:
