“Set Color” and “Set Value” not working properly? Blender
Home Forums Puzzles “Set Color” and “Set Value” not working properly? Blender
  • #34008
    Hello,
    I am creating a configurator where I change some RGB nodes in Blender by clicking on some HTML button I created using puzzles.
    Up until yesterday, the configurator was working fine. In puzzles “set color”, I could choose between the different RGB nodes from a specific material using the dropdown arrow. Today, the puzzles editor cannot fing this RGB node. I’ve created more RGB nodes and I cannot find them as well.
    The same happens with “set value” puzzles. I cannot find my new-created value nodes in Blender.
    Where should I look like? What’s my mistake?
    #34009
    may be the material was renamed, or the export is performed in some other destination?
    #34010
    Yuri,
    Thanks for the quick reply.
    No, it was not that. It’s been a couple of hours trying to solve this. New geometry would be added, but the nodes where nowhere to be found. At last, I found what caused the problem.
    In Blender, I had clicked Ctrl+Shift+T with node wrangler enabled so as to see what my base colour would look like, after multiplying it with an ambient occlusion map. I had to click Ctrl+Shift+T in the Principled BSDF again in order to export it right.
    Thanks for the quick reply again.
    #34012
    sure! glad you worked it out! :good:
