Select an object with its name
Home Forums General Questions Select an object with its name
  • #32206
    johngrigni
    I want to be able to bind html labels to objects by reading data into the app from a CSV file.
    Is there a way in Puzzles to select objects using the object name as text read in from that CSV, in the same way you use an Object Selector puzzle?
    The only thing I can think of is to pre-select all of the potential bind objects in some enormous if-then-else monstrosity: if text = “abc” then set variable ‘object’ = abc object from selector. Is there a more elegant way to do this?
    <<Please disregard, it seems to be working fine now>>
    #32224
    glad you worked it out! :good:
