second slot of puzzle disapear
Home Forums Puzzles second slot of puzzle disapear
  • #26077
    lamthanhle
    Hi Yuri,
    This puzzle have problem ?
    Pls see pic.
    Tks,
    #26117
    Looks like a bug. Will look into this. Thanks!
    #26133
    this is intended behavior – you need to use a procedure with return value:
    #26156
    lamthanhle
    Hi Yuri,
    If use a procedure with return value I can’t call it from [myapp.js], because it dont have this line -> this.procedures[] in visual_logic.js
    Btw, this puzzle have problem too, see pic attached.
    Thanks,
    #26276
    ok we’ll take a look
    #26287
    Hi lamthanhle,
    Thanks, this is a bug indeed, we will fix it in the next verge3d update. As a workaround you can just add the “show” puzzle from the “Object” puzzles tab. You don’t even need to plug anything into it, for example:
    We’ve tried to reproduce that but to no avail. It would be useful if you share a visual_logic.xml file or a whole application where that issue can be reproduced.
    #26437
    lamthanhle
    Hi Yuri,
    Hi Yuri,
    This issue only with my app not the puzzles. I have tested with new app it’s ok, sorry about this mistake.
    Yes, this trick work great.
    Thanks,
    Thanks,[/quote]
    #26443
    lamthanhle
    Hi Yuri,
    Let’s look this pic of proceduce return, I just tested (after post above).
    Thanks,
    FIXED: hix I forgot this -> () :wacko: :wacko: :wacko:
    #26447
    :good:
