Home › Forums › General Questions › scrollable timeline to scroll through an animation
- This topic has 14 replies, 5 voices, and was last updated 4 years, 3 months ago by
gf3d.
2020-12-08 at 9:57 am #36256
gf3d
CustomerHi there , i´m convincing my customer to go the new possibilities that can be realized with Verge3d…..
There is one thing i somehow can´t find how to make it work…..
See the link below….to see what i made sofar….
My customer would like to have a kind of timeline integrated to scroll
through the animation… Is this possible,,,,and if yes…how?Thanks
http://www.gf3d.de/NanaWall_HSW75_Concept_A/NanaWall_HSW75_Concept_A.html
2020-12-08 at 11:00 am #36257Yuri Kovelenov
Staff2020-12-08 at 3:47 pm #36262gf3d
CustomerHI Yuri,
thanks, but this doesn´t help me.
I´ve attached the data for this project.
You will see an object which represents the timeline for now.
So when i move the blue button from left to right within the given limits
i need the animation to go back and forth according to the movement of
of the blue botton.Thanks for your help.
If this works out i will definitly need a license to work with.
Greets
Ger
2020-12-09 at 7:08 am #36268Mikhail Luzyanin
StaffYou need to to use Drag Move puzzle to move your button and then get the position from this button and translate it the same way like it shown above in the video into the animation.
2020-12-09 at 9:24 am #36275gf3d
CustomerHello Mikhail,
thanks for the reply……
I tried this yesterday for a couple of hours…..
the problem was that i wasn+t able to limit the movement of the button
and that the movement of the was wasn´t the same as the movement of the mousei had to move the mouse vertically to move the button horizontally…
i couldn´t figure out why….
any ideas?
Greets
Ger
2020-12-09 at 11:23 am #36292Mikhail Luzyanin
StaffYou can add limit constraint to the object or use If operant to controll the value.
2020-12-09 at 1:30 pm #36301gf3d
CustomerHi Mikhail,
sorry to disturb you again…..
i can´t get it to work……
Since i did send you the dataset for this project…and there is many more…
Is it possible to set up the puzzles in this dataset for me….
Thanks in advance
Greets
Ger
2020-12-09 at 1:59 pm #36302Mikhail Luzyanin
StaffCan’t see any attached files. Only link to the html file.
2020-12-09 at 2:14 pm #36303gf3d
CustomerHi Mikhail,
strange…I´ve attached a *.rar file….
try it again…
Greets
Ger
2020-12-09 at 2:15 pm #36304gf3d
CustomerIf this doesn´t work…..i can send it directly via email…
on what mail addi should i sen it then?
Greets
Ger
2020-12-09 at 3:45 pm #36306Mikhail Luzyanin
StaffIf this doesn´t work…..i can send it directly via email…
You can upload it on file sharing service and share link here.
2020-12-09 at 4:05 pm #36308gf3d
CustomerHi Mikhail,
i´ve uploaded the files onto Dropbox
https://www.dropbox.com/sh/vhod486yl7ejybj/AABuWQ-ZntXJmKlT23CeTW6qa?dl=0
Greets
Ger
2020-12-10 at 12:55 am #36322GLiFTeK
CustomerHey gf3d,
Do you mean something like THIS?User Stefan the Fox on the verge 3D discord server posted that awhile ago.
He also posted a zip file with the project files in it.Find it by searching the channel “puzzles” for him.
Here’s an invite…Hope it helps!
plz share Discord link & on your signature!2020-12-10 at 8:22 am #36346Alexander Kovelenov
Staff@gf3d
Hi, I’ve checked your example. It looks like you’re trying to handle the moment of zero position of your drag control. This is nearly impossible, since the precision of the mouse movements are quite low. Try making your condition like -0.1 < position < 0.1.
The issue with incorrect drag axis is due to parented Scrollbar_Button element. For now, drag puzzles support only word-space movements, so it’s impossible to parent these objects to anything. I’m going to add this to our TODO list, meanwhile you better unparent and reposition your scrollbar.2020-12-10 at 8:53 am #36348gf3d
CustomerHi GlifTek,
yes thats what i mean….
I´ve looked for the zip file….but i don´t find it…..
Can you help me on that?
Greets
Ger
