SCRIPT1002: Syntax error in IE11
Home Forums Puzzles SCRIPT1002: Syntax error in IE11
  • #38122
    The logic doesn’t work when loading the 3D in IE11 and it gives a Script1002 error. Please see attached screenshots
    I’m not sure if you can check the app with this link:
    https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:251e362e5c/applications/3d-Exercise_v2/updated heart 2021.html
    #38147
    From the second picture you posted it seems that your application uses an “exec script” puzzle with some custom code inside it. That code utilizes a javascript feature that is not supported in IE11: arrow functions (the part “s => s.name” on the line 998 in the picture) – that’s why it doesn’t work. You just need to rewrite the code in that “exec script” puzzle via traditional functions.
    #38172
    Solved! Thank you so much! :good:
