- This topic has 24 replies, 4 voices, and was last updated 4 years, 5 months ago by
Yuri Kovelenov.
2020-07-27 at 9:34 pm #30727
swatchyb
CustomerHi Vergers,
Was hoping to find a way at the end of user working in my configurator, to take a screenshot of the product and save it on the server to be used as a visual record of the item on the order, similar to those that have mentioned putting it on a pdf.
After one of Yuri’s posts, searching the forum for “headless”, it looks like this approach could do the job (server sided), but sounds above my abilities.
So, the question is, is there a plan to put this kind of feature into a puzzle?, or is that somehow doable already, using the “take screenshot” puzzle (which works great) in some way?
Many thanks!2020-07-28 at 12:03 pm #30777Yuri Kovelenov
Staff2020-07-29 at 3:56 am #30814swatchyb
CustomerThanks Yuri, good idea – shoulda thought of that.
In taking a quick look, am I on the right track with the attached?, and what hints can you give for naming the images file (e.g. like the prod_id from the server, getting that value the parent (see floating puzzle).
Many thanks!2020-07-30 at 12:43 pm #30931Alexander Kovelenov
StaffHi,
It’s up to you how to name the file, the most important thing is to get the data link returned by the server (see the loaded data puzzle in the Custom Image example) and save it somewhere. In the example, it is saved in the image_url parameter of the current page URL. You, however, may store it in the database or send it to user email, etc.2020-07-31 at 4:48 am #30948swatchyb
CustomerThanks Alexander,
Not sure I get how to get it to save to the server (the path is specified in the puzzle) vs downloading to the client, or the loaded data puzzle functionality. Attached is where I am at, can you tell me what pieces are missing?
Thanks for the clues. You would be surprised how far I have gotten given that I am not a developer at all
Thanks again2020-07-31 at 12:56 pm #31001Alexander Kovelenov
StaffI see where is the hurdle. Path to the send data puzzle is not the file name! It’s a server URL that accepts these files. It looks like:
https://sandbox.soft8soft.com/wp-json/verge3d/v1/upload_file/
Where sandbox.soft8soft.com should be replaced by your own server name.
And this URL stays so notwithstanding your file name. Read more about WordPress uploading service here.
2020-08-16 at 5:18 pm #31615swatchyb
CustomerHi Yuri,
I created that path replacing the server name and using the attached puzzle, but with no luck. Not using WP, but doubt that has anything to do with it. Also hadn’t connected the set link puzzle since I hadn’t gotten that far. Also attached are the Network and Console snips.
Any hints?
Many thanks!2020-08-17 at 4:46 am #31631Yuri Kovelenov
Staff2020-08-18 at 1:34 am #31663swatchyb
CustomerHi Yuri,
Using a pretty standard set up PHP/Linux on a cloud service. Have built a crm web-app using bootstrap/css/mysql stuff, and with v3d as the fun part. Everything else is working well (including v3d :), and this may be my last technical challenge before soft launch. Thanks in advance for your help.2020-08-18 at 4:55 am #31672Yuri Kovelenov
Staff2020-08-19 at 2:35 am #31707swatchyb
CustomerHi Yuri,
Don’t think it returns anything, but then I am not offering a name either. Attached is the simple puzzle I tried, and the response was:<!DOCTYPE HTML PUBLIC “-//IETF//DTD HTML 2.0//EN”>
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL was not found on this server.</p>
<p>Additionally, a 404 Not Found
error was encountered while trying to use an ErrorDocument to handle the request.</p>
</body></html>In a perfect world, there would be a puzzle that went something like:
SEND DATA / +take a screen shot/ TO / +”server path”/ AS ELEMENT/ +”file_name_field” (in parent doc option)I see you have the idea there for WP, both in what you suggested before, and in your e-commerce/ place order/ make a screen shot puzzle. so it is like that, but not tied to WP. Very useful for customer order history of configured products!
Thanks for your help.
2020-08-19 at 6:55 am #31713Yuri Kovelenov
Staff2020-09-16 at 1:28 pm #32939shruthy
ParticipantHI,
I need to take screenshot and save in the local folder i.e., inside application folder – > some folder. Is there a way to do it without using server side url?Thanks,
Shruthy. B2020-09-16 at 2:54 pm #32950swatchyb
CustomerJust to add, my project is stalled on this important feature (auto-saving the screen shot to the server without WordPress). Hoping this might be something on the roadmap for an enhanced puzzle, Yuri
thanks!2020-09-17 at 7:26 am #32962Yuri Kovelenov
StaffHi,
Due to security reasons, web applications that work in the browser are not allowed to access the local file system. The only way is prompt a user dialog for saving a file. Otherwise you need to use some server-side script.
