Same variable puzzle with different product components
Home Forums Puzzles Same variable puzzle with different product components
  • This topic has 3 replies, 2 voices, and was last updated 1 year ago by peet.
  • #69864
    peet
    Hi all,
    Is there any solution to using different product components with the same variables puzzles? I’m planning to create different scenarios in my Composite product. This means I will have many of the same components where only the price is different. So depending on the other selections in the product those components will appear or disappear. Each product component has a different component id.
    As you can see in the attached image, I use the components id’s in the product component puzzle but I need to use these same variable setups with my other components id’s. If I simply duplicate the puzzle and change the product component id, it doesn’t work, can’t handle one variable with different components. The only solution that was working for me was to create separate variable sets with unique names for each product component but this solution made it too chaotic for puzzles. If anyone has a better simple solution, please let me know. :)
    ps.: As you can see in the attached image I have many objects with the same variable sets, I believe this is also could be much simpler. I tried with groups but that doesn’t handle morph targets. If you have any ideas, please let me know.
    Best regards,
    Peter
    #69883
    If it works then it’s good ;-)
    #69915
    peet
    True, but a more tidy and skeezed solution would keep the app less heavy. Just a hint of ideas or guidelines and I would be happy. :-)
    #69977
    peet
    I have made some tests with the unique variable sets that were working previously on other options but unfortunately, it doesn’t work on my new setups. The only difference is that I have much more variable sets. You can see the attached images I have unique names but if I turn on these sets ruin the other one, and destroy the other sets as well. It does not make sense to me what happening but looks like the variables are limited somehow, even though I use different names my values and keys are the same and that causes this problem maybe. What do you think?
