Home › Forums › Bug Reports and Feature Requests › Runtime error
- This topic has 14 replies, 3 voices, and was last updated 4 years, 11 months ago by
Yuri Kovelenov.
2020-04-26 at 7:00 pm #26670
Retailleaum
CustomerHello.
I have this error message and cannot export or view my project. I uninstall 3ds max and Verge 3D to install new but nothing has to do
Can somewone help me?
2020-04-27 at 6:37 am #26682Yuri Kovelenov
Staff2020-04-27 at 9:50 am #26707Retailleaum
Customerok the problem does happen occurs my new scene. Do you have any idea what is blocking?
2020-04-27 at 10:20 am #26711Retailleaum
CustomerI deleted some objects and it works but all the pivot points have moved, the animation no longer makes any sense
2020-04-27 at 12:21 pm #26722Yuri Kovelenov
Staffcan you post here the output of MaxScript Listener console?
2020-04-27 at 12:22 pm #26724Retailleaum
CustomerI don’t andertand
2020-04-27 at 12:23 pm #26726Retailleaum
CustomerWelcome to MAXScript.
V3D-INFO: Initialize Verge3D plugin
V3D-INFO: Exporting glTF 2.0 asset (ASCII)
V3D-INFO: Generating default light
V3D-INFO: Converting to mesh: Balle-1
V3D-INFO: Converting to mesh: GeoSphere002
V3D-INFO: Converting to mesh: GeoSphere003
V3D-INFO: Converting to mesh: GeoSphere004
V3D-INFO: Converting to mesh: Rouleau1
V3D-INFO: Converting to mesh: Rouleau2
V3D-INFO: Converting to mesh: Entrainement1
V3D-INFO: Converting to mesh: Entrainement2
V3D-INFO: Converting to mesh: Entrainement3
V3D-INFO: Converting to mesh: Entrainement4
V3D-INFO: Converting to mesh: Entrainement5
V3D-INFO: Converting to mesh: Entrainement6
V3D-INFO: Converting to mesh: Entrainement7
V3D-INFO: Converting to mesh: Entrainement8
V3D-INFO: Converting to mesh: Entrainement9
V3D-INFO: Converting to mesh: Line_point3
V3D-INFO: Converting to mesh: Line_point2
V3D-INFO: Converting to mesh: Line_point1
V3D-INFO: Converting to mesh: Ruban
— Error occurred in anonymous codeblock; filename: C:\verge3d\max_plugin\verge3d.ms; position: 17463; line: 478
— MAXScript MacroScript Error Exception:
— Runtime error: Invalid index passed into a Max SDK Tab::Addr(const INT_PTR i)
— MAXScript callstack:
— thread data: threadID:3228
— [stack level: 0]
— In sneakPeek(); filename: C:\verge3d\max_plugin\verge3d.ms; position: 17464; line: 478
— member of: StructDef:V3DManagerStruct
— Locals:
— Externals:
— owner: (V3DManagerStruct V3D_MENU_CONTEXT:1905594901 autoAssignAttrs:false settingsFile:”$userscripts/Verge3D/settings.ini” debug:false hasInitiated:true smeClock:dotNetObject:System.Windows.Forms.Timer)
— importPython: Struct member:importPython : V3DManagerStruct.importPython()
— [stack level: 1]
— called from codeblock macroScript: Verge3D_sneakPeek; filename: C:\verge3d\max_plugin\verge3d.ms; position: 501; line: 26
— Locals:
— Externals:
— [stack level: 2]
— called from top-level
— [stack level: 0]
— Locals:
— Externals:
— [stack level: 1]
— Locals:
— Externals:
— [stack level: 2]
V3D-INFO: Converting to mesh: Ref-cam
V3D-INFO: Converting to mesh: ground001
V3D-INFO: Converting to mesh: Ref-target
V3D-INFO: Converting to mesh: Spheretop
V3D-INFO: Converting to mesh: Bordeau
V3D-INFO: Converting to mesh: Rouge
V3D-INFO: Converting to mesh: Blanc
V3D-INFO: Converting to mesh: Gris
V3D-INFO: Converting to mesh: Bordeau001
— [stack level: 0]
— Locals:
— Externals:
— [stack level: 1]
— Locals:
— Externals:
— [stack level: 2]
V3D-INFO: Converting to mesh: Moule_sphere_axe
V3D-INFO: Converting to mesh: Moule_sphere2
V3D-INFO: Converting to mesh: Moule_sphere1
V3D-INFO: Converting to mesh: Balle-2
V3D-INFO: Converting to mesh: Supprt_balle2
V3D-INFO: Converting to mesh: Chemin_balle3
V3D-INFO: Converting to mesh: Line002
V3D-INFO: Converting to mesh: Line003
V3D-INFO: Converting to mesh: Box002
V3D-INFO: Converting to mesh: Box003
V3D-INFO: Converting to mesh: Box004
V3D-INFO: Converting to mesh: Box005
V3D-INFO: Converting to mesh: Line004
V3D-INFO: Converting to mesh: Line005
V3D-INFO: Converting to mesh: Line006
V3D-INFO: Converting to mesh: Line007
V3D-INFO: Converting to mesh: Line008
V3D-INFO: Converting to mesh: Line009
V3D-INFO: Converting to mesh: Line010
V3D-INFO: Converting to mesh: Line011
V3D-INFO: Converting to mesh: Line012
V3D-INFO: Converting to mesh: Line014
V3D-INFO: Converting to mesh: Line015
V3D-INFO: Converting to mesh: Line016
V3D-INFO: Converting to mesh: Line017
V3D-INFO: Converting to mesh: Line018
V3D-INFO: Converting to mesh: Line019
V3D-INFO: Converting to mesh: Line020
V3D-INFO: Converting to mesh: Line021
V3D-INFO: Converting to mesh: Line022
V3D-INFO: Converting to mesh: Line023
V3D-INFO: Converting to mesh: Line024
V3D-INFO: Converting to mesh: Line025
V3D-INFO: Converting to mesh: Line026
V3D-INFO: Converting to mesh: Line027
V3D-INFO: Converting to mesh: Line028
V3D-INFO: Converting to mesh: Cylinder001
V3D-INFO: Converting to mesh: Cylinder002
V3D-INFO: Converting to mesh: Box006
V3D-INFO: Converting to mesh: Cylinder003
V3D-INFO: Converting to mesh: Cylinder004
V3D-INFO: Converting to mesh: Cylinder005
V3D-INFO: Converting to mesh: Cylinder006
V3D-INFO: Converting to mesh: Box007
V3D-INFO: Converting to mesh: Cylinder007
V3D-INFO: Converting to mesh: Cylinder009
V3D-INFO: Converting to mesh: Cylinder010
V3D-INFO: Converting to mesh: Cylinder011
V3D-INFO: Converting to mesh: GeoSphere0022
V3D-INFO: Converting to mesh: GeoSphere0032
V3D-INFO: Converting to mesh: GeoSphere0042
V3D-INFO: Converting to mesh: Line_point32
V3D-INFO: Converting to mesh: Line_point22
V3D-INFO: Converting to mesh: Line_point12
V3D-INFO: Converting to mesh: Chemin_balle32
V3D-INFO: Converting to mesh: Box001
— [stack level: 0]
— Locals:
— Externals:
— [stack level: 1]
— Locals:
— Externals:
— [stack level: 2]
V3D-INFO: Converting to mesh: Chemin_balle322020-04-27 at 12:36 pm #26728Alexander Kovelenov
Staff2020-04-27 at 12:40 pm #26729Retailleaum
Customer3ds max 2020 22.0.0.757
and the last vertion of Verge3d
And the other big problème is the pivot point explosion
2020-04-27 at 12:43 pm #26730Retailleaum
Customeri try withe sds max 2019 and it’s okay for the pivot points. But the puzzle window is only white. I don’t see anything
2020-04-27 at 1:32 pm #26735Yuri Kovelenov
Staff2020-04-27 at 2:13 pm #26737Retailleaum
CustomerWere can i find this?
2020-04-28 at 5:38 am #26758Yuri Kovelenov
Staff2020-04-28 at 8:20 am #26803Retailleaum
Customerok. I find it. I try and it works a little better but I have to completely refresh the animation, Verg3D does not understand the Path Constrain and spline…
Thank you for your time
2020-04-29 at 6:21 am #26865Yuri Kovelenov
Staff -
