Home › Forums › General Questions › Rotate Camera 360 degrees in Vertical direction
Tagged: 360 degrees, camera, camera rotation, vertical rotation
- This topic has 12 replies, 6 voices, and was last updated 11 months, 1 week ago by
kdv.
2021-12-25 at 6:18 am #48289
vern
CustomerHello,
I really need to allow the camera to rotate 360 degrees vertically. I see the limit is set to 180 degrees.Is there a way I can override that so the camera for my application can rotate 360 vertically just like it can horizontally?
It’s something I really really need for my app.
Vern
2021-12-25 at 8:58 am #48291Alexander Kovelenov
StaffHi,
Can you elaborate a bit regarding this matter? If we allow camera to move beyond 180 degrees it might do one of the following (both quite unusual):1) flip upside down so all the objects will appear upside down
2) make a hasty rotation in the upper or bottom point (+180/-180)Also, by rotating 360 vertically you mean rotation with mouse or automatic rotation via Puzzles?
2021-12-25 at 1:43 pm #48294vern
CustomerI just really need the 3D model to be viewed freely, without any camera restriction at all.
Please see this link to see what I mean exactly.
There should be a way to move around freely in 3D the same way you do in the 3D modeling software for example (like 3DS Max or Blender) with no problem or hasty movement at a certain point like you mentioned.
Could you please show me how to to change the limit to be 360 degree movement vertically?
Vern
2021-12-25 at 3:29 pm #48296Alexander Kovelenov
Staff2021-12-25 at 4:01 pm #48297vern
CustomerYou’re welcome!
Okay, awesome! :)
So for now I guess I can’t change it yet?
Vern
2021-12-28 at 6:21 am #48337Yuri Kovelenov
StaffSo for now I guess I can’t change it yet?
nope, but we’ll try to make it possible asap
2021-12-28 at 3:53 pm #48351vern
CustomerOkay, thank you very much!!
That’s sounds great, I’m really looking forward to trying it. :)
Vern
2022-01-17 at 11:27 am #48684Nurgeldi Dovletov
StaffHi,
the feature will be added in next pre-release!Verge3D Developer
2022-01-17 at 3:41 pm #48688vern
CustomerWow, you guys really are incredible!! Thank you very very much, and I can’t wait to use it!! :)
Very much appreciated indeed.
Regards,
Vern2022-01-19 at 3:02 pm #48739vern
CustomerDo you know about when the next pre-release will be? :)
2022-01-24 at 3:22 pm #48819Yuri Kovelenov
Staff2024-04-24 at 4:01 am #72480aortalab
CustomerAny update on this please?
2024-04-24 at 5:07 am #72481kdv
ParticipantI really need to allow the camera to rotate 360 degrees vertically. I see the limit is set to 180 degrees.
