Rigged mesh breaks apart
Home Forums Graphics / Blender Rigged mesh breaks apart
  • #36531
    gregor1
    Hi – I have an animated character that I made in Blender. It worked great in Blender and in Verge, but then I added the hat. It looks fine in Blender, but in Verge the mesh falls apart. I have a Subdivision modifier on it, but it happens with or without it. Any ideas?
    https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:dc5f3c613e/applications/SantaMonster/SantaMonster.html
    #36572
    Can you attach a blend file with the hat?
    #36615
    gregor1
    Here are the parts involved. It’s obviously the rig that’s breaking it, but the worst parts are where the bones have very little influence.
    #36618
    This happens because most of the vertixes has more than 4 weight per vertex, the limit is not more than 4 weights per vertex. You need to clean up your mesh this way that each vertex will have max 4 weight per vertex.
    #36665
    gregor1
    Wow – that was a hair-puller, until I found “Limit Total” in the Weights menu in Weight Paint. It got a lot worse before it got better, but then it only took about a second.
    Thanks! I got there eventually!
