Home › Forums › Programming › retrieving global variable from another iframe
- This topic has 16 replies, 4 voices, and was last updated 10 months, 1 week ago by
c4cc.
2020-03-18 at 3:49 am #24765
GLiFTeKCustomerhi,
this is driving me nuts. hope someone can help…I’ve designed my index.html file to have my verge3d container in a div not iframe.
within my puzzles network, I’m using html puzzles to create a draggable panel div with jquery ui.
within that i have sliders made with my html puzzles.. that control my verge object.
works perfect.got the verge3d environment filling the window, and a draggable control panel controlling the objects..
so, to spice things up, i’ve made a new batch of fancy animated sliders and buttons through Adobe Animate CC.
it uses create.js/easel.js to make an HTML5 canvas stage.so now to implement it (and replace) the old sliders.. I’ve put an iframe before the original sliders div into the draggable panel, and src’d the Animate exported html into it.
now they’re both in the panel one on top of the other(on the y not z)
.. the original works fine.. but not the top..i havent connected the NEW slider’s values yet.
what i’m doing is having the slider’s authored JS create a global variable (for now (testVarVar).. in the Adobe Animate JS authoring environment.
that code looks like this:
this.testVarVar = that.parent.sliderTrack_MC.testVar.text; console.log("testVarVar: ",this.testVarVar);and it’s console printout is working fine.
trying to get the Verge3D to listen for it i’ve tried a number of ways.. but i just couldn’t find the right puzzles to get it’s value so i made a call JS that looks like this..
app.ExternalInterface.getTestVarVar = function() { var thisVar = testVarVar; return thisVar; }now i know that just that won’t work.
i left it blank because i tried all these ways of referencing testVarVar…
this.testVarVar, window.testVarVar, document.testVarVar, window.document.testVarVar, exportRoot.testVarVarno dice … just can’t get Verge3D’s js to see the variable at all.
Adobe Animate help and create.js forums/docs all go on to talk about exportRoot being the root of the create.js scope that supposedly is accessible from external querys. Adobe Animate Canvas Movieclip Hierarchy
maybe i’m not declaring that testVarVar variable in the right place or right manner? “this” should be defining it on the window level scope right? that’s accessible to Verge right?
Scope and ‘this’i need to get past this, it’s been 2 days…
thanks!
plz share Discord link & on your signature!2020-03-18 at 9:36 am #24771
Yuri KovelenovStaff2020-03-18 at 12:04 pm #24777
GLiFTeKCustomerHi,
The “this” in the line
likely relates to an instance of some JavaScript Object (class), implemented by Adobe Animate.
Instead of “this”, you might try “window” so that the variable becomes global.yea no see i tried that.
are you sure verge is ABLE accept or get global variables??
this isn’t the first time ive struggled on this for a long time..last time was about a week.. and i decided to give up on it out of frustration and go a completely different route because i couldn’t get verge to simply exchange variables between another window.
do you know where a good example of this happening in the examples where i can look at the exact code at the sending and receiving end and compare it to what i’m doing?? like literally seeing it function live.
thnnxx
plz share Discord link & on your signature!2020-03-18 at 12:45 pm #24779
Yuri KovelenovStaff2020-03-19 at 4:33 am #24783
GLiFTeKCustomeruuuuhhhhgg!!! wOOOO!
fixed it with just using window.parent.testVarVar = that.testVarVar;
(“that” is “this”)then the js call return window.parent.testVarVar.
alrighty then…
onwards!
plz share Discord link & on your signature!2020-03-19 at 5:44 am #24784
GLiFTeKCustomeranother thing.. in doing the opposite…
i got variables FROM the adobe controls TO the verge window..
but now..to make variable in the verge window accessible globally for the Adobe controls to get…
i set a JS call saying…
window.parent.testVarVarBack = testVarVarBack;
(where testVarVarBack is a defined puzzle variable in verge…doesn’t work..
is there a puzzles way that can do this better? or a bettwe way? do i have to use get elementbId ? i tried.. it came up undefined.
thanks.
EDIT: fixed.. just had to send the variable with the JS call, dur.
plz share Discord link & on your signature!2020-03-19 at 6:16 am #24785
Yuri KovelenovStaff2020-03-27 at 12:02 am #25017
GLiFTeKCustomerglad you worked it out!
Re-reading this and you had already recommended I use window.parent..woops..didn’t understand how you were suggesting, which was pretty straight forward..
Having an issue with this again.
The only way I can access the window.parent.variables LIVE in puzzles is to have a procedure running the “every frame” puzzle with my “call js” puzzle that updates my puzzle variable to what the window.parent one is, whether the variable is changing or not.
(This variable is the value of a custom control changed often)This method is a performance hog right? I tried the “has html element changed” for the window.parent value but no dice…
I CAN do something in my “run your script here” section of myApp.js file… But how do I refer to my puzzles variables in that section?
Is there something I should precede puzzle variables I want to change from there with? document.container.puzzleVar etc??P.s. in going to try what you showed user jstubb with the contentWindow approach over here –> Unable to Reference Updated Global Object From External Interface
plz share Discord link & on your signature!2020-03-27 at 3:57 am #25019
GLiFTeKCustomerIf I wrote a MutationObserver in my my app.js to check if the window.parent.variable has changed, I’d have the v3d. procedure (call a puzzle procedure) and have that puzzle run my jscall that gets the value(in posts above).. That would work, but.. Is there a way to just. Cut out the middle man and call the app.ExternalInterface (my js call) right from there instead of going back to the puzzle procedure then to do that?
Thanks.
plz share Discord link & on your signature!2020-03-27 at 9:32 am #25044
Yuri KovelenovStaffHi,
if you just setting a variable and do just some simple operations then it is ok for each frame
sure you can use
v3d.apps[0].ExternalInterfacenamespace to call it from anywhere2020-03-27 at 2:34 pm #25058
GLiFTeKCustomerok thank you very much for your answers!
anything on the specifics of prefacing syntax for setting a variable that’s in puzzles FROM the “run your code here” part of myApp.js ?
plz share Discord link & on your signature!2020-03-28 at 8:00 am #25070
Yuri KovelenovStaff2020-03-29 at 3:08 am #25095
GLiFTeKCustomerthis post keeps disappearing when i edit it.
‘ok i had assumed that about puzzles variables for security.
good news…
for anyone who reads this later here’s some info:
(ad this is super important info if you’re in need of your code communicating between sibling iframes and/or the parent document.I’m activating verge’s container content through the html5 controls now.
my verge3d is in a div not an iframe, but i have a control panel for the verge3D objects in a separate iframe (a stack of custom html5 canvas range sliders).to call puzzle procedures in the parent window with the verge3d div FROM the iframe’s js file i’m using:
parent.v3d.puzzles.procedures.testFire();(example)to run a function in the “run your code here” part of the myAwesomeApp.js (your project’s js) file i did
this in the iframe’s js:
window.parent.testFire();with this in the “run your code here” part:
window.parent.testFire = function(){ v3d.puzzles.procedures.testFire(); console.log("window.parent.testFire FIRED"); };and vice versa to call a function in the iframe from the parent (my verge3d container in the parent doc)
example:
my parent doc has this:
document.getElementById('sliders_panel_iframe').contentDocument.functionToFire();which calls this from the iframe window with the Adobe Animate CC HTML canvas :
document.functionToFire = function(){ console.log("functionToFire fired"); };(not sure about how to access the app.ExternalInterface.someJScallFunction();
functions though externally.. maybe name a window.parent.variable to the externalinterface function?)now i can control when the variables are updated between them instead of having it do it every frame, (which was causing some issues when that’s all that was in the functionality)
so with a little help..
I’m “Glad I worked it out”
thanks!
plz share Discord link & on your signature!2020-03-29 at 6:05 am #25097
Yuri KovelenovStaffnot sure about how to access the app.ExternalInterface.someJScallFunction();
functions though externally..try this one:
v3d.apps[0].ExternalInterface.someJScallFunction()2020-06-15 at 4:08 am #28831
dssctrCustomerYou helped tremendously Thank You GlifTek!
