Retrieve objects size
Home Forums Puzzles Retrieve objects size
  • #68313
    kuze
    Hi all,
    I’m asking if there is a way to get a selected object size (width, length, height) using puzzles.
    Have you any advice?
    thank you
    #68314
    https://www.soft8soft.com/docs/manual/en/puzzles/Objects.html#get_object_dimension
    #68315
    kuze
    Thank you. I found it on the user manual but I couldn’t find it in puzzle object menu.
    Maybe it depends on Verge3D app version I’m using?
    I’m working with 3.9.0 version.
    • This reply was modified 1 year, 4 months ago by kuze.
    #68317
    in 3.9.0 this puzzle doesn’t exist yet :unsure:
    #70898
    Brameister
    I’m trying to use this puzzle, but it doesn’t work with morphed objects. The manual says “The puzzle has some limitations. For morphed objects, it returns maximum dimensions the object can be morphed to”.
    Is there any way to get dynamic measurements for objects as they are morphed? An example would be to get the current width of an object as it is changed by the user (set morph factor puzzle).
    #70912
    You can….but you need to save the value at the time of the last shape key input and then recall that variable when the request to know its size.
    The Shape key values are 0 to 1…you will need to remap those to your start dimension and end dimenison and then use that value.
    #70939
    Brameister
    Awesome insight, got it to work now. Thanks for the help Xeon!
