- This topic has 9 replies, 3 voices, and was last updated 5 years ago by
Yuri Kovelenov.
2019-11-01 at 4:47 am #20927
GLiFTeK
Customerhi
i’m wondering if this version might have a bug with the custom props feature.
i’ve tested it multiple times in the recommended way and it’s coming up as undefined in the console. using Version 2.16.0pre2
i see 16 full is out . i will upgrade.
hopefully it works there.
thanksEDIT: same with 16.full
plz share Discord link & on your signature!2019-11-01 at 7:46 am #20936Ivan Lyubovnikov
StaffHi, did you enable the “Export Custom Properties” option in the “Scene->Verge3D Settings” panel? You get undefined if you don’t enable it.
2019-11-01 at 9:24 am #20939GLiFTeK
CustomerHi, did you enable the “Export Custom Properties” option in the “Scene->Verge3D Settings” panel? You get undefined if you don’t enable it.
All I’m getting in the scene section’s verge3d settings is this..
ALSO : i am using blender 2.8 not 2.81
plz share Discord link & on your signature!2019-11-01 at 9:43 am #20945GLiFTeK
Customeri found it.
it is not in Scene> Verge3D settings.
it is in context: RENDER> Verge3D settings.
that was the issue.
FIXED.
we’re ROCKIN’ NOW!P.S. : I think you maybe should make that ON by default or put that very important tidbit of info in the manual entry of the custom props (should make this step here avoidable)
plz share Discord link & on your signature!2019-11-01 at 11:18 pm #20952GLiFTeK
Customerso.. back to the issue that i thought was the problem in the beginning…
is that i can’t call the object with the custom properties through using a variable.
even with the “variable value by name” puzzle.
using the selector puzzle for an actual object works just fine.
not variable.that was the original idea… to loop through all of the custom props for retrieving unique data of many objects that are loaded into the scene .. hence need for a changing variable each “i” in loop.
plz share Discord link & on your signature!2019-11-18 at 1:23 pm #21159Ivan Lyubovnikov
StaffHi,
Sorry for the late answer. Can you post the puzzles setup that doesn’t work? Or a link to a test example?
2020-02-12 at 5:53 pm #23512GLiFTeK
CustomerHi,
Sorry for the late answer. Can you post the puzzles setup that doesn’t work? Or a link to a test example?was just about to post again about this but remembered that i had posted about it before.
yeah… it’s still not working for me.
i have the export settings checked…
but there’s no way to designate an Object that the custom props are attached to.i experimented and named one property “custom properties” and made an object “custom properties” and it appears in puzzles as “custom properties.001”
but it doesn’t produce any dictionary keys.
in your example it shows using “cube” .. how was “cube” initially connected to the Custom Properties section of the Scene Data Pallets?
if you select an object. .then make custom props.. then select another object.. they stay there…. so they’re not specific to an object as far as i can tell.
do you name the property after an object like i did?thanks
thanks
plz share Discord link & on your signature!2020-02-13 at 8:22 am #23521Ivan Lyubovnikov
Staffin your example it shows using “cube” .. how was “cube” initially connected to the Custom Properties section of the Scene Data Pallets?
Oh, you mean Custom Properties on a scene itself?
Scenes actually get custom properties from the World panel not from the Scene panel. This may be considered a bug, I think we will fix it in the near future. Anyway, the puzzle “get custom props” doesn’t work with scenes, only with objects (this also may be supported in the future).So, right now the most convenient way of using custom properties is to add them directly to an object (Object > Custom Properties) and then use the puzzle as usual.
2020-02-13 at 12:03 pm #23530GLiFTeK
Customeroook..
/./facepalm//
had no idea that was there.. thought i had looked profusely..got it working now, thnx.
(REAL valuable feature actually.)
plz share Discord link & on your signature!2020-02-13 at 12:43 pm #23533Yuri Kovelenov
Staff -
