- This topic has 76 replies, 10 voices, and was last updated 6 years, 1 month ago by
Yuri Kovelenov.
2018-03-27 at 6:16 pm #3187
johngrigni
CustomerIs there a way to replace the texture without the rest of the material? I want to use a normal map and a diffuse map, and want to swap out one but not the other based on an icon selection. Is this something I have to write code for, because I have no idea how to do that, or even where such code should go.
Ideally, I could read them from a folder/directory with a bunch of other bitmap textures.
2018-03-28 at 8:26 am #3213Yuri Kovelenov
Staff2018-03-28 at 9:40 am #3217vincent
CustomerIf I understand the request, I do this way.
I work on Blender and I make a clone of my object with a new Texture ( Image texture), and I do : invisible the clone on the Verge 3D (with the icon : camera).2018-03-28 at 10:04 am #3219johngrigni
CustomerThe problem is the client has over 100 textures they want to use, and loading that many invisible objects at the start is prohibitive.
So if it is coding only, where does the code go? I can see an example, does this get appended to the html file, or a separate JavaScript file, or in the Blender file itself?
2018-03-28 at 10:31 am #3221Yuri Kovelenov
StaffSo if it is coding only, where does the code go? I
JS code is added to your_app.js file located in your app folder. When you open this file, look for runCode() – you add your own code inside this function.
The following snippet replaces the diffuse texture of the Cube object with a new image:
function runCode() { // add your code here, e.g. console.log('Hello, World!'); app.scene.traverse(function(obj){ if (obj.name == 'Cube') { var loader = new v3d.TextureLoader(); loader.load('./new_image.png', function(texture) { obj.material.map = texture; }) } }); }
2018-03-28 at 10:35 am #3222vincent
CustomerI understand better your request. The images textures files (png, jpeg) are in the web site and more you approach more than you need pixels in the texture. For me it’s a problem of 3d in a web browser.
I ask a question : Is it possible to make a texture (image texture) only with code ?2018-03-28 at 10:45 am #3223Yuri Kovelenov
StaffIs it possible to make a texture (image texture) only with code ?
Does the code snippet above answer your question?
2018-03-28 at 1:00 pm #3224johngrigni
CustomerThank you for your timely reply!
So, how do I make that work for 100+ textures? Do I make the ‘./new_image.png’ into a variable that gets fed into the function, and have preview icons that basically set the variable and then call the function?
Since I’m working with two different maps (diffuse and normal), do I need to add that as a variable as well, or make it two different functions?
2018-03-28 at 1:40 pm #3225Yuri Kovelenov
StaffYep!
function runCode() { function changeTexture(objName, diffuseURL, normalURL) { app.scene.traverse(function(obj){ if (obj.name == objName) { var loader = new v3d.TextureLoader(); loader.load(diffuseURL, function(texture) { obj.material.map = texture; }) loader.load(normalURL, function(texture) { obj.material.normalMap = texture; }) } }); } changeTexture('Cube', './new_image_diffuse.png', './new_image_normal.png'); } });
2018-03-28 at 2:27 pm #3226vincent
CustomerI was participate, because I have imagine this case study. But I am only designer and for the moment I am not a coder. Thank you Yuri.
2018-03-28 at 2:37 pm #3227Yuri Kovelenov
Staff2018-03-29 at 3:35 pm #3263johngrigni
CustomerI keep getting an error:
TypeError: v3dApp.ExternalInterface.changeTexture is not a function. (In ‘v3dApp.ExternalInterface.changeTexture(objName, difffuseURL, normalURL)’, ‘v3dApp.ExternalInterface.changeTexture’ is undefined)I put the script into the Ati.js file after the comment in the runCode function.
I’m attaching a screenshot of my test file to see if I’ve messed up the puzzles to call the function.
2018-03-29 at 3:47 pm #3265Yuri Kovelenov
Staffyour function should be registered first, see this topic for more info https://www.soft8soft.com/topic/purpose-of-prepareexternalinterface/#post-3262
also there is an example in the SDK called ExternalCall, where this approach is demoed
2018-03-29 at 6:54 pm #3271johngrigni
CustomerPerhaps I am too much of a noob, because it’s not working at all.
In the .js file for my project, the second to last function is prepareExternalInterface(app) and the comment says to register functions in app.ExternalInterface to call them from puzzles, and sites an example where myJSFunction is defined as a simple console.log. So is registering the same as defining?
So do I need to define the function there, or under function runCode() or both places? I’m very confused.
No matter what I do I’m getting an error: “TypeError: appInstance.ExternalInterface.changeTextures is not a function. (In ‘appInstance.ExternalInterface.changeTextures(objName, diffuseURL, normalURL)’, ‘appInstance.ExternalInterface.changeTextures’ is undefined)”2018-03-29 at 7:18 pm #3272johngrigni
CustomerAlso, when I send a changeTexture() call from runCode() with different URL values, it loads the correct textures but doesn’t apply UVs to them. Is there something for specifying the UV to load the textures in the material (in the Blender file the mesh just has the one default named ‘UVMap’)?
