Home › Forums › Graphics / Maya › Refraction of moving water (From Maya)
- This topic has 11 replies, 3 voices, and was last updated 4 years ago by
Alexander Kovelenov.
2021-02-09 at 1:19 am #38223
benleo
ParticipantHello,
I’m looking for a workflow that can render water deformations on the surface of an object and also refraction.
I got a bump working (I think I see it on the suface) that’s animating but I cannot get refraction to work.
I tried the blend mode and I tried both post processing puzzles “Simple Refraction” and “Screen Space” – no luck.
I’m basically trying to do this:
https://cdn.soft8soft.com/demo/examples/webgl_refraction.htmlIf there is a workflow I could follow, I’d greatly appreciate some insights.
Many thanks
2021-02-09 at 12:49 pm #38262Mikhail Luzyanin
StaffHere’s a simple example for you. If you want to use refraction you need to leave Blend Type of object as opaque then enable transmission and enable simple refraction for this object.
2021-02-09 at 9:14 pm #38303benleo
ParticipantThank-you, much appreciated.
Your scene file however does not show a verge section in the AiStandard shader, there is no “Opaque” or “Blend” setting in your scene on the shader. The manual says use “Blend” and you are saying use “opaque”.
I cannot reproduce what you did in my scene.
I’ve attached your shader settings as an image.
I imported your shader added it to a poly sphere and it’s completely opaqueAttachments:
You must be logged in to view attached files.2021-02-09 at 9:20 pm #38306benleo
ParticipantHere is your plane imported into my scene with your shader applied with the puzzle applied. Maya 2020 on Catalina
You must be logged in to view attached files.2021-02-09 at 10:56 pm #38309benleo
ParticipantHere is a video recording of your scene not being updatable or reproducible, if I place any objects in the scene they turn opaque black, if I export your shader they turn objects invisible in the verge scene.
You must be logged in to view attached files.2021-02-09 at 11:02 pm #38312benleo
ParticipantHere is a video link to me using your scene and ending up with black opaque objects.
2021-02-09 at 11:27 pm #38313benleo
ParticipantHere is your scene after I added a sphere, applied the water shader, it rendered black and I deleted the sphere.
Basically exact same scene.2021-02-10 at 8:31 am #38325Mikhail Luzyanin
StaffThanks for the example will look at it.
2021-02-10 at 6:38 pm #38372benleo
ParticipantThat would be great, i’m trying to do a project and it needs water.
Right now it looks like a bug.2021-02-10 at 7:33 pm #38373benleo
I think it’s because you created that file in maya 2019 on PC.
On Mac there is no Verge 3d settings in AiStandard Shader available.Looks to me like refraction is not possible on MAc
2021-02-10 at 9:27 pm #38374benleo
ParticipantSo after doing some extensive testing on PC and MAC on Maya 2019 and 2020:
The only version of Maya that has Verge3D settings on an AiStandard Shader is maya 2020 on Mac and refraction does not work.
The test file you sent is immutable and renders black if i save over it and export gltf on ALL versions.I would love to use this software on a real project but this is essentially the only stumbling block.
Could you write a patch to get refraction to work?
2021-02-17 at 12:31 pm #38661Alexander Kovelenov
Staff -
