Reflectionplane in combination with Light Path Camera Ray world shader
Home Forums Graphics / Blender Reflectionplane in combination with Light Path Camera Ray world shader
  • #74535
    huib
    Hello!
    In Blender I’ve created a world shader using the Light Path node splitting the visible part of the camera vs the reflective/lighting part of the shader as is shown in the Verge3d manual.
    World Shader
    This seems to work fine until I use it in combination with the ReflectionPlane when weird things start to happen. It looks like the ” is Camera rays” are visible in the ReflectionPlane.
    verge3d screenshot
    Is this a known limitation or am I maybe missing something :D ?
    • This topic was modified 9 months, 4 weeks ago by huib.
    #74537
    Can you share the example file?
    #74558
    huib
    Sure thing, I changed the colors in the worldshader to make it more visible, attached the file below (made in Blender 4.0)
    #74563
    So, where did you find an issue? The reflection plane is reflecting your visible backgroud map B (and all visible objects) while A is used as an environment map for the image-based lighting (IBL). Everything is acoording to the nodes logic. The reflection plane reflects what you see on the screen, so-called screen-space reflections.
    #74567
    Yes, this is proper behaviour, you just need to add on environment something that would reflect and increase size of the reflection plate so it cover all your water mesh.
