Reference batched geo
Home Forums Puzzles Reference batched geo
  • #70148
    Ben
    Hi, is there any way to reference newly batched geometry using puzzles? For example if I batch a bunch of cubes, how to I assign the resulting batch object to a variable so it can be moved/deleted etc later?
    Thanks
    #70149
    Hi Ben,
    it is not possible to explicitly assign predefined names to batches, but it follows a certain naming convention as can be seen on the screenshot https://www.soft8soft.com/docs/manual/en/puzzles/Scenes.html#batch_geometry
    #70151
    Ben
    Thanks Yuri,
    That helped me get it working:
    1. Add all clones of object to clone_list
    2. batch geometry of clone_list
    3. Set a variable to the following using a create text node plugged into a get object node:
    “object_x”
    get length of clone_list
    “_batch”
    Variable now points to the batched geo. Thanks!
