Reative paths & multiple blend files
Home Forums General Questions Reative paths & multiple blend files
  • #25297
    I am new to Verge3D, and have two questions.
    I I have two Blend files in my applications directory – only one file can be manipulated using Puzzles. How can I get access to multiple Blend files (stored in the same directory) when using puzzles?
    Can I load a scene stored outside the current application using a relative path? I have tried with no success.
    I am using Win10/Blender.
    Kjetil
    #25298
    Hi Kjetil,
    After exporting both .blend files to .gltf, you can load/append them to the main scene using these puzzles:
    https://www.soft8soft.com/docs/manual/en/puzzles/Scenes.html
    See also demos: Load Unload and Jewelry Configurator.
    You can use the above-mentioned Scene puzzles and load your scene from outside the application folder.
