raycaster is not work
Home Forums Puzzles raycaster is not work
  • #23275
    wlhm1984
    i want to check obj1 is intersect obj2 or not in axis x direction,i use this method,but it is not work,can you give some advice?thanks very much!
    var raycaster = new v3d.Raycaster(obj1.position,new v3d.Vector3(1, 0, 0),0,10000);
    var intersects = raycaster.intersectObject(obj2);
    #23307
    I tested the raycaster on simple scene with a couple objects and it works for me. Can you share a test case where it doesn’t work?
