Quote for custom configurator, API back to Revit
Home Forums Jobs and Opportunities Quote for custom configurator, API back to Revit
  • #31960
    vizgraphics
    Hello,
    3d assets will be coming from Revit into 3ds Max. All models and HTML UI will be provided from third-party. I’m needing a skilled Verge3D developer who can provide an estimate for the following.
    – UI to change length, width, height and position of objects by input text fields. Position can be adjusted with drag. Need to show dimensions on model. Model will consist of 3 parts (top, middle, base), each with values to be adjusted.
    – Adjust pricing based on parts selected
    – Send final values back to Revit via Revit API
    Again all 3d models and UI layout will be provided via third-party. Just need someone to make it wll work.
    #31976
    CyberFox
    Hi!
    We will be happy to help you. We work with companies from all the world, please, see examples of our work: https://cyber-fox.net/en/
    Please send a detailed description of the project to our: info@cyber-fox.net.
    We also need an example of your 3D model to Estimate right deadline for your project.
