Puzzles to slide animation along an X or Y-axis, using keyboard events?
Home Forums Puzzles Puzzles to slide animation along an X or Y-axis, using keyboard events?
Viewing 15 posts - 1 through 15 (of 18 total)
  • #66974
    c4cc
    I wanna use Loops, Variables, Procedures, Objects, and if necessary, logic puzzles, to slide an animation along the X or Y axis at a smooth, visible pace as long as I hold down a key.
    Maybe I’d use a Variables to set the initial position of my Character’s parent object at -0.3 at the Y-axis, using Set Object. Then I’d set a Variables name to the Parent object, to get the latter’s initial axis position.
    For Procedures, I can use loop “repeat while – do”. Problem is, how do I keep adding 0.08 increments to the Y-axis for as long as the key is held down?
    kurumii
    my 2nd attempt to do a procedure:
    kurumii
    • This topic was modified 1 year, 5 months ago by c4cc.
    #66977
    https://v3d.net/o2p
    If necessary? :scratch: Without logic puzzles you will do nothing.
    #66988
    c4cc
    Thanks for your answer, but for some reason, my character isn’t moving…
    kurumii
    • This reply was modified 1 year, 5 months ago by c4cc.
    #66996
    You’ve made 8 mistakes on the left.
    #67008
    c4cc
    Thanks. God damn, it should of been made clear that uppercase letter keys are not recognized by the puzzles as key input.
    Also, I wanna make my character turn around 180 (e.g., right to left, or vice versa) after pressing left or right keys twice in a row. How do I use logic for this, given that puzzle logic “and” does not accept number operations:
    kurumii
    #67009
    The problem was not in the upper case recognition. WASD – with Shift pressed.
    #67028
    c4cc
    I see, makes sense.
    Also, besides this, how do I require two simultaneous key inputs to produce a different function (e.g., key S + 4 to shoot diagonally)?
    #67088
    c4cc
    https://v3d.net/o2p
    Also, did you use physics puzzles here? If you did, can you please show me?
    #67089
    I didn’t use physics puzzles. Every puzzle used in that demo is shown on the screenhot.
    #67090
    c4cc
    I see. Then how did you prevent the cube from falling through the floor, or going through the walls?
    #67091
    Objects are not trying to fall down without physics.
    There are no walls in that demo. Only one cube with the “Limit location” constraint applied in Blender and one plane.
    #67092
    c4cc
    Thanks, your answer made sense.
    Better still if the new key event puzzles do not mess up the original one
    I don’t mean to rush you, but I hope you can address these two other questions of mine when you have the time, too.
    #67093
    That’s your quest. Think. Try. I showed you how to use keys for moving. All the rest is possible but on the paid basis.
    #67094
    c4cc
    Yes, I did try, as per these screenshots:
    kurumii
    #67095
    That was a bad try. It’s impossible to multiply a boolean value (true or false) by 2.
    What are the double click or double key hit? Just two single clicks or hits made within a short period of time (≈0.2s or 200ms).
