- This topic has 12 replies, 3 voices, and was last updated 8 years, 2 months ago by
Pepper KUN.
2018-07-13 at 1:55 am #5681
Pepper KUNCustomerHi, I wondering is there any way to control specific input node by puzzles or JavaScript code? I’d like to make a bar with custom height set by user. I know it is difficult to do that for now. Will this feature be supported in future? How can I change specific value in GLTF by using JavaScript? I search it on net but get nothing.
Noob on blender and any other things.
2018-07-13 at 2:45 am #5682
Pepper KUNCustomerMy bar is a percentage circle like below. For now I can only animate it rather than let it custom by user.
2018-07-13 at 2:48 am #5685
Pepper KUNCustomerHere is my Material Node.
2018-07-13 at 7:17 am #5688
Mikhail LuzyaninStaffHi, I wondering is there any way to control specific input node by puzzles or JavaScript code?
You can animate a value node, as you already did and use a Play Animation puzzle to start it or a Set Keyframe puzzle to set a specific position of animation.
2018-07-13 at 9:56 am #5693
Pepper KUNCustomerThx,but what about with color animation. The color of circle can be changed . I’d like to have a blue circle in 80 percent, a red circle in 10 percent and a yellow circle also in 80 percent. how to achieve this in one material?
2018-07-13 at 10:08 am #5694
Mikhail LuzyaninStaffI’d like to have a blue circle in 80 percent, a red circle in 10 percent and a yellow circle also in 80 percent.
I dont know what you mean under to have in 80 precentagee yellow nad red at the same time, but I created an example for you may be it’ll help.
2018-07-13 at 10:41 am #5697
Pepper KUNCustomerwhat I mean is separating two kind of input node. The web user can custom the progress and the color of the percentage circle. User can’t custom the color and the percentage of the circle separately if I use animation clip.
2018-07-13 at 10:43 am #5700
Mikhail LuzyaninStaffwhat I mean is separating two kind of input node. The web user can custom the progress and the color of the percentage circle. User can’t custom the color and the percentage of the circle if I use animation clip.
Sorry, but there’s no way yet to separate this processes.
2018-07-13 at 10:51 am #5702
Pepper KUNCustomerAny way changing it with JavaScript? I can see the input value in my GLTF file. however I can’t change this value with responsive way.
2018-07-13 at 10:58 am #5703
Pepper KUNCustomer2018-07-13 at 11:01 am #5705
Pepper KUNCustomer.
2018-07-13 at 2:58 pm #5719
Yuri KovelenovStaffAny way changing it with JavaScript? I can see the input value in my GLTF file. however I can’t change this value with responsive way.
Yes you can do it. Something like this:
var object = app.scene.getObjectByName("Circle"); var mat = object.material; var index = mat.nodeValueMap['Value.001']; mat.nodeValue[index] = 0.5; // new value2018-07-13 at 5:11 pm #5723
Pepper KUNCustomerThank you Yuri. :)
