Puzzle to control the swap of multiple materials assigned to one Object.
Home Forums Puzzles Puzzle to control the swap of multiple materials assigned to one Object.
  • #14264
    heryson
    Hello,
    there is a way to you make a puzzle to swap a specific material by name assigned in an object with multiple materials assigned?
    For exemple:
    I have an object named house and I want to change the material of the wall paiting named “Oak” to another material named “Teka”. The Object house has other materials assigned in other parts, metalics, hooftop, doors, etc…
    and I dont want to make this especific parts to be unique objects, it has to be all in the object named House.
    If yes, it would be very helpfull!
    #14389
    heryson
    Hello again,
    I searched ind the decumentation section and found a puzzle to replace a texture in a material to another. And another that I can get the name of an specific material assigned in to an object. The problem is that I cant switch an assigned material to another material. Do you know anything that I can do to solve it, if not in a puzzle, programming?
    Thanks, I’ll wait for an answer.
    #14414
    Sorry but the engine design restricts it to be only one material per object. However, you can use groups/collections to operate your objects as a single entity.
    #14417
    heryson
    Thanks Yuri,
    Ok, so I will try this way! :good:
    #69905
    melisa1209
    how to make button next and preview only use puzzle?
    • This reply was modified 1 year, 2 months ago by melisa1209.
