Puzzle “New Line” with line feed and carriage return
Home Forums Puzzles Puzzle “New Line” with line feed and carriage return
  • #57203
    Tim
    Hello everyone,
    I am currently connecting a product configurator with a client’s webshop system via PHP. Therefore I am sending a formatted text file to PHP. The format is very specific. Basically it is a text document (.txt or .sql) where each line describes an article. This text is prepared in the Verge 3D application by using the “New line”-Puzzle a lot.
    Now it turns out that the client requires that each line ends with a line break with carriage return (CRLF). Unfortunately, the “New line”-Puzzle does not and a line with “CR“ (Carriage Return CHR(13)) but with “LF” (Line Feed CHR(10)).
    Is it possible to implement a line break with carriage return in Verge? If so, how would I achieve this? I would be happy about your help. Thank you in advance.
    #57205
    you can do it on your own. Open “puzzles.min.js”, find this
    textNewLine=function(e){return["'\\n'"
    and replace '\\n' with '\\r\\n'
    #57266
    Tim
    Hi kdv77kdv, that works :yahoo:
    Thank you very much for your reply!
    I changed it to
    Blockly.JavaScript.textNewLine=function(e){return["'\\r\\n'",
    It turned out that it is also mandatory to resave the puzzles editor, so this new info is pulled into the project files.
    Also I found a lot of “puzzles.min.js” in outdated installation paths.
    It will probably be important to manually update this in each new version of Verge 3D.
    #57272
    Perhaps we should add a setting to this puzzle. :yes:
