puzzle mix
Home Forums General Questions puzzle mix
  • #34244
    farzinkhodadadi
    i have 2 different object and one (html interface button)
    i want to make an object 1 active. so when i click on interface button it will show components on that object 1.
    and if i active another object(object 2) and click on same interface button, show components for object 2.
    how can i do this?
    i try to use puzzles like this .
    but the problem is if i click on first object and then second object and after i use interface button. it will show components on both object in same time
    what can i do?
    #34250
    Hi, I think you can do it by using the following puzzle setup:
    You can use a variable puzzle to store the active (or last clicked) object. This is what “when clicked” does in the example.
    And inside “on event of click” you just check if that variable equals to a particular object, or in other words which object is currently active, and then show/hide their corresponding components.
    #34269
    farzinkhodadadi
    thank you so much, it was great
