Publish to LinkedIn
Home Forums General Questions Publish to LinkedIn
  • #11964
    Pottsie
    Hello!
    It seems that posting to LinkedIn doesn’t work.
    After I publish via App Manager, and then given options to choose the platform, I am unable to view the post after I make the selection. For example, LinkedIn.
    I select the option/icon for LinkedIn, then attempt to view the post. It opens to a new tab but fails to load the player. Just FYI.
    Check out my sketch book :) | www.instagram.com/b.potts.art/
    #11993
    yep, LinkedIn cuts URL parameters so the sharing does not work for apps loaded with the player using URL. It works for standard htmls though https://www.linkedin.com/feed/update/urn:li:activity:6507153095561089024
    #12024
    Pottsie
    Ok. So are you saying I will just need to copy/paste the URL directly into a Linkedin post (bypassing the share option)?
    It appears the player doesn’t seem to load regardless? I’m sorry for all the questions, just trying to understand. :)
    This is the URL generated from the file manager (I’ve just used the cube example)…
    https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:3330f49894/player/player.html
    #12027
    The problem is only with player+URL apps – LinkedIn seem to cut the load=path/to/scene parameter and for this reason only player.html file is loaded – which is blank white.
    Such applications are not considered “standard” ;-) Those we use to avoid updating the engine files during development. If you create a new production app with the App Manager it will work fine with LinkedIn.
