procedures puzzles issues
Home Forums Bug Reports and Feature Requests procedures puzzles issues
  • #51332
    FunJoy.Tech
    Bug report: procedures puzzles may cause the puzzles editor not to work correctly in some scenarios.
    1: “Delete all puzzles” in the main tab will print errors in the console if the created procedure puzzles are not in the same tab;
    2: “Delete all puzzles” in a custom tab may not work if procedure puzzles are not in the same tab or there’re also procedure puzzles in other custom tabs.
    Generally, these errors do not affect the regular operation of the editor. Still, this occasionally leads to the save operation not being performed in some cases.
    Try this a minimal scene: procedures_console_issue.zip
    #51338
    Hi Lijun,
    thank for the report and the example project. We’ll check it out ASAP.
    #51381
    Hi FunJoy.Tech,
    Thanks for the test case! We’ve managed to fix this bug!
    #51459
    FunJoy.Tech
    Hi FunJoy.Tech,
    Hi Ivan, Thanks! I have another question about the gltf loader:
    Is the load scene puzzle incompatible with glTF 2.0? If export a set with the Blender default glTF 2.0 exporter, it works fine with the append scene puzzle but does not work with the load scene puzzle. I made a tweak of the load unload demo with a Sketchfab model for the minimal test:
    Scene: https://v3d.net/6ff archive: https://v3d.net/6fg
    console msg
    #51662
    Thanks again for the test!
    There was a bug in the gltf loader, it’ll be fixed in the next verge3d update. Other than that the load scene puzzle should be compatible with the GLTF 2.0 format.
    #51777
    FunJoy.Tech
    Hi, Ivan. In the 4.0 pre4, the append scene puzzle also has this issue now.
    #51784
    we’ll include this fix in the next preview!
