Problem with uploading HTML to own website
Home Forums General Questions Problem with uploading HTML to own website
  • #23495
    doka
    Hello everyone,
    I have a problem to get my Verge3D file work on my own website.
    Everytime I start the file the loading screen stops at 18% and then I get the info that the loading failed.
    Does somebody know how I can fix this problem?
    #23498
    This error indicates that the compressed version of your gltf file is not found on the server. Make sure you enabled asset compression when exporting from 3ds Max
    https://www.soft8soft.com/docs/manual/en/introduction/Asset-compression.html
    #23548
    doka1
    thanks for your answer. I tried it but have still the same issue.
    #23553
    Interesting. Can you check if the gltf file is actually present by the html file in the server directory?
    Another idea: may be you accidentally changed the case of the file name? Unlike with Windows, on the web the URLs are case-sensitive.
