Problem with shadows on Blender.
Home Forums Bug Reports and Feature Requests Problem with shadows on Blender.
  • #4585
    Dzynek
    Hello
    I noticed that the shadow is slightly shifted in Blender. (Verge3D 2.4, Blender 2.79b)
    Blurred shadow (default) causes strong slowdown.
    Is it possible to make objects (transparent) disappear shadow when animating objects disappear?
    Regards
    #4586
    Hello
    Try to play with Bias parameter of the shadows on the light. Also try to set far an near parameters as low as possible and also Size parameter too.
    Sorry, but I can’t understand the behavior, can you give step by step explanation what you want from object to do?
    #4595
    Dzynek
    I apologize for the delay and English :)
    The reduction of the FAR parameter for the Sun has helped :)
    Reduce SIZE Sun: Screenshot_1.png, Screenshot_2.png (cuts shadows)
    SOFT PCF and PCF Screenshot_3.png, Screenshot_4.png (gives artifacts)
    SOFT PCF it slows down very much.
    #4600
    Dzynek
    Soft PCF and Sun Radius: 10 – Screenshot_5.png
    How to make a transparent object shadows? (Screenshot_6.png, Screenshot_7.png)
    #4604
    Dzynek
    I have noticed yet: Teapot Heater is very slow and FB only black.
    #4607
    You need to tweak Bias o reduce of them.
    I mean keep it as much as possible lower but that gives you good result, so just keep it as lower as you can but nor extreme:).
    Sorry but only way to remove shadows is to hide the object completely. Transperency does not effect shadows.
    #4608
    This model will be visible only on facebook posts, because we remove environment map to reduse file size. If you want to see it just connect eny environment map to the scene.
