Problem Loading Verge directly on my Website with Version 4.2.0
Home Forums Bug Reports and Feature Requests Problem Loading Verge directly on my Website with Version 4.2.0
  • This topic has 1 reply, 2 voices, and was last updated 2 years ago by kdv.
  • #60001
    Armin Bastl
    Hello There,
    i am trying to include a Verge app into a webpage directly by including the JS and CSS Files:
    <script src="/somefolder/3d/test_app/v3d.js"></script>
    <script src="/somefolder/3d/test_app/test_app.js"></script>
    <link rel="stylesheet" type="text/css" href="/somefolder/3d/test_app/test_app.css">
    <div id="v3d-container">
    <div id="fullscreen_button" class="fullscreen-button fullscreen-open" title="Toggle fullscreen mode">
    </div>
    </div>
    This had worked flawlessly with Verge Version 4.0.0 and 4.0.1, but since Updating to 4.2.0 the import of visual_logic.js inside v3d.js tries to get the file by the current url rather than the directory where the v3d.js is located.
    ERROR:
    GET https://someurl.net/someslug/somepage/visual_logic.js net::ERR_ABORTED 404
    Expected behaviour: The import of visual_logic should also work if v3d.js is not loaded from the verge app’s root folder.
    #60003
    all you need is just to copy directly the app’s folder somewhere into your server folder. nothing else. why do you change paths to js/css files? they are relative and lead to the app’s folder provided test_app.html is located in the same folder. Did you move test_app.html? In your case test_app.js can’t find visual_logic.js in the root of the app’s folder. Looks like you moved it somewhere else…
