Problem in 3.9 3dsmax
Home Forums Bug Reports and Feature Requests Problem in 3.9 3dsmax
  • #48633
    karonte
    Sorry if it’s not the right sub-forum.
    I installed the new 3.9 plugin for 3dsmax. i see 2 problems.
    1) it’s SLOWER than 3.8 when i create gltf. it takes 20 SECONDS to export! ( the 3.8 took 3 seconds).
    2) in the console i see errors if I enable AO (v3d.js:1 v3d.App: wrong postprocessing effect enablePostprocessing @ v3d.js:1)
    Someone use it?
    Regards.
    MR
    #48637
    Are you using the old AO puzzle, or enable AO in Max export settings? Also make sure you actually updated your app to v. 3.9.
    #48647
    karonte
    Yes I did. I updated the project. and i use only the export setting for the AO. And what about the slowdown on Export? I think it’s because i enabled Gltf2 option in materials and the computation ( to merge the 3 maps). Could it be?
    MR
    #48674
    will it work faster if disabled?
    as of AO, please follow up this topic
    Ambient occlusion Problem
