Previous project file not render correctly in latest version.
Home Forums Bug Reports and Feature Requests Previous project file not render correctly in latest version.
  • #8400
    Philip Fong
    My project file before version 2.8.0 environment map does not orient correctly and seam stretch. Please take a look at the file attached.
    The correct previous export: http://cmy.com.my/profile/publications/butterfly/butterfly.html
    #8403
    Hi Philip, thanks for reporting it. We’re going to check your issue and will get back to you soon. :good:
    X | FB | LinkedIn
    #8405
    This bug happens when an equirectangular texture assigned to the world. We will fix it in the upcoming Verge3D release. For now, you can either assign a CubeMap-based texture or switch to Cycles node-based environment.
    X | FB | LinkedIn
    #8406
    Philip Fong
    Ok, thank you.
