Stop object movement and restore previous object position?
Home Forums Puzzles Stop object movement and restore previous object position?
Viewing 15 posts - 1 through 15 (of 31 total)
  • #67851
    c4cc
    deleted
    • This topic was modified 1 year, 4 months ago by c4cc.
    #67953
    c4cc
    deleted
    • This reply was modified 1 year, 5 months ago by c4cc.
    • This reply was modified 1 year, 4 months ago by c4cc.
    #68346
    c4cc
    Credit to Alexander for suggesting using physics ghost bodies.
    I want to prevent certain objects passing through other objects, using physics ghost bodies.
    How do I use restore previous object position? I checked object puzzles, but
    none mentioned reversing value/inputs.
    My physic puzzles:
    original-drawn-by-nanashinayuzu-mochi-53d2788a0d5e217f8b28d256c728bf04
    My movement puzzles:
    When I tried put in the movement puzzles under the detect collision puzzles, it caused my character to teleport away instead of preventing it going through objects.
    #68349
    bigmike814
    See the app I included. This is a test I did for items touching and repositioning.
    https://v3d.net/psj
    Also, when you’re moving the object are you only wanting it to move slightly? You’re moving it along the 7 by .03 from side to side. I think you’re wanting to use the “change position by” puzzle.
    #68351
    c4cc
    May I see its puzzles, especially for objects touching and repositioning?
    I wanna move that object around at moderate speed, as a 2d playable character. I don’t want moving characters to phase through walls.
    What’s this “”change position by” puzzle? I’ve never heard of such a puzzle.
    #68352
    bigmike814
    I attached the file in a zip. You’ll have to download it and add it to your app folder. Look under where it says attachments.
    Yeah but you’re setting it to the y position. It’s going to move there not a slight movement. Use the change position to move it slightly.
    #68354
    bigmike814
    There are a few procedures you’ll need to achieve this. But here is the main one.
    • This reply was modified 1 year, 4 months ago by bigmike814.
    #68356
    c4cc
    I did try to view your app in App manager, but could not see its puzzles.
    Also, is “change local transform” object puzzle the “change position” puzzle you mentioned?
    Edit: I tried what you suggested, but still the same
    https://ibb.co/3s64Dd2
    Thanks, I’ll get back to you later, after trying this
    #68363
    bigmike814
    It should work. I tested it to make sure and it works on my end. Are you seeing this in the app manager?
    #68365
    bigmike814
    You’ll want to get the position when not touching and when touching set the position to the variable you used to get the position when not touching. Also when not touching use the change position. That will allow you to change it by that amount, not actually set it to that location.
    Try to get the file I sent working and mess with it. It will help you understand the ghosting better.
    #68366
    c4cc
    I can see it, but can’t access the puzzles.
    #68377
    #68399
    bigmike814
    https://v3d.net/put
    #68411
    c4cc
    I searched inside that folder, which file do I go to for those puzzles?
    #68412
    All files in that folder. Just copy it to the folder with your other apps.
