Home › Forums › General Questions › Presale question
- This topic has 8 replies, 2 voices, and was last updated 4 years, 8 months ago by
Alexander Kovelenov.
2020-07-15 at 4:14 pm #30147
milord85
Participantwe are working with verge 3d and woocommerce.
We are using the verge 3d free plugin to try different solutions and we made some great results.
However we are trying to implement the verge 3d with custom woocommerce select menu.
I link you with one that work as a charm: https://caos-store.com/product/soap-holder-wall-mounted/We want to lunch this store online as soon as possible. The company that has ordered this work to our web agency need an answer from us becouse they need to know if to buy or not verge 3d. but the final question is: does verge 3d woocommerce plugin work with select menu like the link below? does we need to buy the plugin in order to have this kind of menu to work properly? here the link to a product with a menu that we are not able to use: https://caos-store.com/product/test-colora/
Thanks for your valuable support, kind regards
2020-07-15 at 4:34 pm #30149Alexander Kovelenov
StaffHi,
WooCommerce selection menus are supported by Verge3D as product attributes. I’ve checked your second product page and it looks like the issue is with the global attributes that customized on a per-plugin basis.
I actually have good news on that matter! The upcoming pre-release (Verge3D 3.3 pre2) which we’re going to release by the end of this week (or maybe next week) will come with global product attributes supported. So please reassure your client, the issue will be resolved soon!
2020-07-16 at 12:45 pm #30208Alexander Kovelenov
Staff2020-07-21 at 2:39 pm #30419milord85
ParticipantHello Alexander,
thank you for your quick reply. I am trying to use your updated version (3.3 pre2) for pc a updated plugin for wordpress. I’ve also re-exported the application but there is still the same issue with the global attributes.*/WORKING EXAMPLE WITH LOCAL ATTRIBUTES*/
*/NOT WORKING EXAMPLE WITH GLOBAL ATTRIBUTES*/
waiting for your feedback.
thank you again2020-07-21 at 4:57 pm #30428Alexander Kovelenov
Staff2020-07-21 at 5:03 pm #30429Alexander Kovelenov
Staff2020-07-23 at 1:34 pm #30521milord85
ParticipantThank you Alexander. now it works fine!
2020-07-23 at 1:38 pm #30522milord85
ParticipantI am using 3DS MAX to create a translucent material similar to the linked image
https://caos-store.com/wp-content/uploads/2020/05/Caos-Compendio-Colori-Accessori-04-Rosso-1.jpg
In the following link you can find my result in white version, but is not so realistic.
Any suggestions?
2020-07-23 at 2:32 pm #30530Alexander Kovelenov
Staff -
