post processing on one object and not another?
Home Forums Puzzles post processing on one object and not another?
  • This topic has 5 replies, 3 voices, and was last updated 2 years ago by xeon.
  • #59917
    auriea
    I have an object that I want to appear as ‘fast’ and the afterimage post processing puzzle does that nicely. is there a way to have that effect appear just on one object and not on the entire scene?
    #59918
    no. but you can disable the afterimage pass after the “fast” object has appeared
    app.postprocessing.afterimagePass.enabled = false;
    #59919
    auriea
    thank you for your answer. in this case would i need to load the object separately from the rest of the scene?
    #59920
    no. just disable the afterimage pass after your Flash has appeared and stopped. But if you want the afterimage pass affecting your Flash constantly (excluding all other objects) then just forget it )))
    #59921
    auriea
    okay. thank you. i understand :)
    #59965
    If you have one object you need special processing on …. you may want to try creating a sprite for that object. We often use sprite maps for glows, and things on objects and just put a point to camera constraint on them. Not sure of your intent but this may be a solution.
