Point display xyz values
Home Forums Plugins Point display xyz values
  • #63827
    structor
    First post on the forum. Just got Verge3D.
    I use the blender version.
    I am looking for a plugin that displays the xyz of my .obj in the webinterface. A pointer were you could add a point and the point displays the xyz values of the given object were it is placed. A snapping function to the .obj should be good so the placement ensure that you are “on” the obj when placing the object.
    Does anybody know if this exist or how to do this?
    Regards
    #63863
    Hi and welcome to the Forums!
    You can get the coordinates with transform puzzles and display them with texture from text.
    As for movements, there are drag puzzles for that.
    X | FB | LinkedIn
    #63865
    structor
    Hello Alexander and thank you for your reply – can you or somebody show me an example how the puzzle should fit together to make this work.
    I have tried alot of variations but I think I am missing something vital. If you just kick me in the correct direction (more than you have :)) then I think I will be on my way..
    Regards
