playing chunk of animation forward and backward
Home Forums Programming playing chunk of animation forward and backward
  • #33134
    s.imboden
    ( Verge version 3.3.1 – exporting models from Blender )
    I need to playback chunks of an animation, in forward and in backward direction.
    to play forward from time 3 to time 4 I do:
    var x=app.actions[0];
    var x.setLoop( v3d.LoopOnce);
    x.reset(); x.time=3; x.getClip().duration=4;
    to play backward from time 4 to time 3 I tried:
    x.reset(); x.time=4; x.timeScale=-1; x.getClip().duration=3;
    x.reset(); x.time=4; x.timeScale=-1; x.getClip().duration=-1;
    none of these work, so, whats the right way to play a chunk of an animation backward ?
    thanks in advance — Silvano
    #33143
    Hi Silvano,
    You might take a look at the code that is generated by this puzzle that creates a chunk of animation.
    Also you might inspect the code generated by this puzzle to make it play in reverse.
    The code can be found in the file visual_logic.js in your app folder.
    #33158
    s.imboden
    thank you very much :-)
    Silvano
