Play animation through runCode function
Home Forums General Questions Play animation through runCode function
  • This topic has 3 replies, 2 voices, and was last updated 3 years ago by kdv.
  • #56583
    sazzrro
    Hello, I’m wondering what method I should be using in order to play an animation of an object with code. After learning about the runCode function, I’ve been able to do other things to objects like change their position, material, and switch cameras; however, I haven’t yet found the right method to use in order to play an animation this way. My resource for seeing what methods/properties are available is found here:
    Resource
    I noticed that the doc says to not change the .animate method unless you know what you’re doing so I don’t think that’s the one I’m looking for, but I could be wrong
    #56586
    function runCode(app) {
      const action = v3d.SceneUtils.getAnimationActionByName(app, 'farmer_mesh');
      action.play();
    #56587
    sazzrro
    Thanks, I got it to work with that code. I had to use the reset method before using the play method to have it run
    #56589
    you can stop all actions before running the chosen one
    app.mixer.stopAllAction();
