Placement error in Verge3D Network
Home Forums Bug Reports and Feature Requests Placement error in Verge3D Network
  • #2159
    xfish3
    I made an attachment (Dron). It is normally displayed on my local computer both in the “Verge3D App Manager” and in the browser. All interactivity works.
    At the very beginning, when I created an application template through the App Manager, it is normally placed in the Verge3D Network. But after creating 3D objects and an algorithm in Puzzles, the application does not reside in the Verge3D Network. When you click on the corresponding button, there is no reaction.
    All built-in applications are placed normally in Verge3D Network.
    Three times the application has been remodeled, and each time it’s the same
    Tell me please:
    1. What is the reason for this behavior of Verge3D App Manager?
    2. Are there alternative ways to host my application in Verge3D Network?
    #2162
    It takes up to 1 hour for a newly-uploaded application to propagate through the CDN. If there is an emergency and you cannot wait, just modify the name of your app folder so that it will be uploaded to a different remote location and become immediately available by a new URL.
    #2164
    xfish3
    I changed the name of the folder of my application. But when you click on the “Verge3D Network” button, nothing happens either.
    I tried to change the name of all the files. After that, the application does not open at all. Apparently, somewhere in the auxiliary files the old name is spelled out?
    #2167
    xfish3
    Made a new application, re-added 3D elements and everything turned out. Thank you!
    https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:7aca5dded6/applications/Drone/Drone.html
    True, when loading the load percentage in the end was 168% :-) I made a screenshot at boot time
    #2168
    I just tried this renaming/uploading trick and it works for me. Only the app folder needs to be renamed.
    Does it always show 0%?
    #2170
    xfish3
    We simultaneously wrote in the topic :-)
    #2171
    ok, great you figured it out :good:
