I recently added a mesh to the blender model I have been using for years and applied a couple different materials – one that is used elsewhere in the model (named ‘DECKTREAD’) and one new one (named ‘MTL2.002’). After exporting as gltf to my project folder the MTL2.002 material shows up as expected as the same color that was set in blender, but the DECKTREAD material shows up as bright pink.
The other mesh objects that use this DECKTREAD material are showing the correct color and have no issues.
I have seen this pink color before and if I remember right it has something to do with “textures” does it not? Why would this new mesh object be the only one in the project that isn’t correctly displaying the DECKTREAD material?
You must be
logged in to view attached files.
