Pick action to consider cut-out map?
Home Forums General Questions Pick action to consider cut-out map?
  • #32382
    vklein
    I have some sophisticated shaped icons made of 3d planes with an opacity masked material (modus mask) on them. Is there a way to let the “when clicked” event be only fired if the click occured inside the opac portion of the Icon? SO having a quadratic plane as object for an arbituary (pics of electro-tools) shaped icon? The same would be fine for any other event too (hover, etc.)
    To clarify, not Verge register the click on the first hit geometry, regardless of opacity.
    #32398
    Unfortunately, click, hover and other events works only with the geometry and will not respect a transparency.
