Physics performance
Home Forums General Questions Physics performance
  • #78979
    swith23
    I have been looking into verge 3D physics and tested the pinball interactive however for me for some reason the physics seemed a little slow and sometimes glitchy. I’m not sure if this is just an issue for me or a limitation of the software for now? Can anyone advice?
    #78982
    In my experience with V3D physics has many use cases. The pinball game if played long enough will uncover some issues with the demo app. I have not dug into it deep enough to determine if its a game engine issue or a demo programming issue. This sort of thing will be up to you the developer to determine if the interaction the physics engine provides is sufficient for your needs. I believe V3D uses the Bullet engine called Ammo.JS. You can find many examples of it being used in Three.JS to get a better idea of what you can do with it in Verge3D.
    I think if you go into it with a realistic understanding of how the physics engine works and see how its being used in other demos you might be very pleased.
