Physical Material with Alpha and glTF 2.0 compatible
Home Forums Graphics / 3ds Max Physical Material with Alpha and glTF 2.0 compatible
  • #51829
    jamjam
    Hey,
    I can´t figure out how to use an alpha with PhysicalMaterial and “glTF 2.0 compatible”.
    What´s the correct way to connect the PNG/JPEG?
    I´m still on 3ds Max 2019 so I can´t use the new glTF-material.
    Thanks!
    Best,
    Gerald
    #51901
    You need to put it inside a base color map, the gltf compat material will automatically get it from there.
    #51944
    jamjam
    Thanks for your reply!
    It works well for Verge3D and in GLTF Format, but when exporting to USDZ to view in AR on iPhone the alpha doesn´t work.
    Any help is much appreciated.
    #51969
    Hi, AR on iOS uses USDZ format which is not currently support transparency. Working on it now, please check the upcoming 4.0 pre-release build.
    X | FB | LinkedIn
    #51977
    jamjam
    Thanks for the info.
    Is this a general limitation or only with PhysicalMaterial?
    Would it work with the new gltf material in 3ds max 2023 right now?
