Performance Tip!
Home Forums Tutorials Performance Tip!
  • #54216
    haris
    I found this code can help you to make your scene performance better if your objects are static.
    Verge 3d performance tip
    Note: this code can stop your objects from moving
    Regards,
    Haris imran
    harisimran1012@gmail.com
    #54258
    :good:
    #54302
    NaxosCG
    Interesting…
    Will it prevent objects to change color / material ?
    Also, where do you put this puzzle, in the main tab, on first place ?
    #54307
    haris
    No it will not prevent material changing you can choose exec script puzzle from advance tab and paste this code and it is not necessory to put the puzzle in a specific condition just add code and you are good to go B-)
    #54310
    NaxosCG
    I’ll test that soon.
    Thank you.
    #54329
    What static objects need to be stopped from moving if they are already not moving? ))) Performance monitor in Chrome shows that there is no difference at all…
