password protected features in verge3d
Home Forums General Questions password protected features in verge3d
  • #48806
    visualizer
    Hi
    Is it possible to provide a password protection to click based events?
    may be protect some pop ups, popup window opening on annotation clicking or otherwise to have password protected access?
    example – A Global illumination example –
    Can I restrict some click based interactions on p/w?
    it can be camera tween motion or it can be change wall colour or switch on-off light… whatever.
    Than could become a next level feature I guess.
    #48814
    Here are some insights.
    The most robust way is to implement server-side authentication, and check the user login/password against the server. Then you can allow the app to load the protected parts of your app from the server using an authenticated request.
    A simpler method is to encode the password into the app itself. But a determined user still can hack into the code and disable the protection entirely.
