Passing Parameters to WebGLRenderer
Home Forums Programming Passing Parameters to WebGLRenderer
  • #35068
    Alex TAYLOR
    Hi!
    I’m sometimes working with models imported from a colleague, and I have depth clash issues when zooming out.
    Researching a little it and testing with these model, it appears that setting logarithmicDepthBuffer=true solves this problem.
    So far I have confirmed this works by hard-coding a change in v3d.js, which is obviously not good practice!
    What is the correct way to pass a parameter to be used when the new renderer is initialised? Is there a puzzle that covers this, or something that could be added to $myapp.js ?
    Thanks!
    #35079
    for now, the only reasonable way to do so is to override App class. Find it in the src/extras/App.js script inside your Verge3D distribution.
    Please note that using logarithmicDepthBuffer can affect the performance of your app in a negative way. Perhaps you should try other options – e.g increasing near clipping distance for your camera might help as well.
    X | FB | LinkedIn
    #35083
    Alex TAYLOR
    Thanks Alexander,
    Yes, I saw the warning in the docs about performance issues – I’ll test and see if it’s acceptable for the nature of the models. Thanks for the tip on near clipping distance also!
    Cheers, Alex
