Parse Value from Puzzles to the project code
Home Forums Puzzles Parse Value from Puzzles to the project code
  • #21480
    justin_blender
    I think this is a rather simple problem but i did not figure out how to do it.
    I want to use some jquery elements for my project. Maybe this can also be entirely integrated into puzzles?
    But here is what I try to do:
    I create a variable via puzzles, say “boolean_x” and set it to false
    On a specific event in the puzzle script it turns true and then an individual script shall be started. That is why I want to call the variable in my project script like “if v3d.puzzles.boolean_x == true” or ” “if v3d.puzzles.variables.boolean_x == true“? Those syntax don’t work.
    Thank you in advance!
    #21481
    Hello,
    at the moment only procedure puzzles can be directly called from JavaScript. See more here:
    https://www.soft8soft.com/docs/manual/en/introduction/Using-JavaScript.html
    #21489
    justin_blender
    Okay I will check out if I can find a work around using a procedure. Thanks Yuri!
    #21505
    justin_blender
    Ok now I had time to try that. It is actually pretty easy. Sorry for obviously not reading closely enough through the wiki :wacko:
    But now I have two more questions:
    What for do you set the “input name” of the JSFunction? It seems to be not used anywhere else and has no effect if I change it.
    Instead, each time I change the name, a new variable under this name appears under “variables”. If I call this variable, the content is not defined. Also I am struggling to delete those created variables again.
    Thanks again!
    #21513
    glad you worked it out!
    You can use those input name puzzles to add arguments (input parameters) to your procedures. See more info here
    https://www.soft8soft.com/docs/manual/en/puzzles/Procedures.html
