Outline around the objects
Home Forums Puzzles Outline around the objects
  • #5606
    vincent
    Outline around the objects when my mouse is hover, the function is grey !
    #5609
    You need to enable it at the scene setup first directly in the Blender.
    #9905
    jedank
    Hi, did you mean render panel? because I don’t see any outline setting in blender scene panel. I’ve enabled that, but still the puzzle is unable.
    #9931
    Yes, you should enable Outline under the Render tab, re-export your scene, reload the Puzzles editor and then the outline puzzle gets unlocked in the Objects category.
    [UPDATE] I recall you posted the characteristics of your video card here – Intel HD Graphics 3000, right? I have a suspicion that it may not support outlining at all. Does the Teapot Heater demo shows outlining for you if you are hovering with the mouse above objects?
